Radio and door locks not working now
Old Jul 20, 2024 | 08:37 PM
Youtube is helpful for this kind of stuff. Here is a video I found.
Old Jul 22, 2024 | 05:32 PM
ldreidjr's Avatar
Ok. I checked 2 and 10. 10, constant power, getting no voltage. 2, with the key acc in spot 2, working. It has good ground continuity. So, for sure no constant power. All fuses checked. Where do I now go?
Question, what happens if I put 12 volts into where 10 goes in radio? I would think then radio would come on. That is what I am missing most. Short term is that ok??
Old Jul 22, 2024 | 07:10 PM
I'm not a fan of even bypassing wiring until you do some more detctive work on why you are missing 12V. If you have a blown fuse and t 12V into the constant hot wire to the radio, you could cause an electrical fire. I isn't worth the risk for just getting the radio to work.
#2 and #10 share the same fuse, so the fuse is likely good. The wht/grn wire going to the radio comes from the passenger fuse box out of connector 12 or 18 in the diagram below. It will be on the back of the fuse box (opposite side from the fuses). I don't know the which connector or pin has the wht/grn and hopefully there is only 1 wht/grn wire leaving the fuse box. Unplug the stereo and the fuse box connector, then use the continuity (or resistance) test on your meter on pin 10 of the radio and the wht/grn wire(s) on connector 12 or 18. You want to check the integrity of the white/green wire from the fuse box to the stereo.
Also inspect the pins and wire harness for signs of corrosion or burning.
Let us know what you find.
Old Jul 22, 2024 | 07:43 PM
ldreidjr's Avatar
Ok, I totally agree then on NOT splicing in 12v. I will now move to your next steps with gr/wh wire.
Old Jul 22, 2024 | 08:39 PM
ldreidjr's Avatar
Looked for a video showing what to take loose to get to the back of passenger side fuse box. Havent found yet. Do you have it?
Old Jul 22, 2024 | 09:05 PM
The shop manual doesn't have one. First step is to disconnect the car battery. The next step is to remove the glove box. Search for videos on how to change the cabin air filter on a 98 accord. That should give you most of the steps needed to access the back side of that fuse box. You might not need all the steps, but it also doesn't look terribly difficult.
camman
Nov 20, 2013 01:15 PM
paulson524
Aug 10, 2013 10:13 AM
paksen
May 18, 2012 08:07 PM
jdarrah66
Feb 22, 2012 06:09 PM
Antarctica
Oct 5, 2010 08:33 PM
