Rattle/Vibration @ approx. 1800 RPM
Old Jun 6, 2006 | 03:00 AM
Chiovnidca's Avatar
Default RE: Rattle/Vibration @ approx. 1800 RPM
ORIGINAL: deserthonda
bulletin # 94-041,, effects 94-96 accords,,
it says to replace gaskets, bolts, nuts and springs on the mid pipe ,,, ( the small exh pipe between frt pipe and cat )
Now i do not know if that is exactly the noise you hear , i would have to listen to it to confirm it , but it sounds like the same symptom
Yep, that's the one i'm talking about, dont even waste your time with it.
Old Jun 6, 2006 | 03:54 PM
nixalot's Avatar
Thanks guys... I think I'll just go ahead and put a header on it and be done with it... [:-]
BTW... do you guys know anything about DNX brand headers?
Old Mar 22, 2007 | 12:03 PM
accordwagoneer's Avatar
My 96 Accord 4 cylinder has made this famous 'Honda Buzz' noise since new. It is most noticeable on mornings below 50 degrees and right about 1800-2100 rpm. It goes away in 5 minutes. The noise originates from the short section of pipe in front of the cat. converter. I think this is just below the 'A-pipe.' It's a very annoying sound.
The dealer tried all sorts of tightenings, gaskets, springs, etc.There is a bullentin or recall about this noise.This did nothing so they pronounced it a 'characteristic of the car.' This was ten years ago.
I figured it was a harmonic vibration in cold exhaust pipes. So I tooksix 1/2 dia. x 4 inch bolts, cut off the heads, and fastened the bolts in an even pattern with 2 high quality stainless hose clamps around the short pipe in front of the cat. This works very well - the additional weight of the bolts dampens the vibration just enough that I am not bothered by it anymore. My other 96 Accord 4 cylinder does not make the buzz - go figure. But it sure is fun to explain this mess of bolts and hose clamps on the exhaust pipe to every mechanic who wants to take it off.......
HighwayStar
Jun 15, 2015 10:18 PM
inspector9
May 23, 2012 05:16 PM
partschanga
Feb 2, 2010 01:08 AM
accordfan222
Nov 14, 2007 12:24 PM
nixalot
Aug 10, 2006 04:54 AM
