is re-wiring of sensor 1 safe?
Old Dec 20, 2008 | 07:36 AM
salipoh2
Default is re-wiring of sensor 1 safe?
Hello Moderators!.. I just want to ask if re-wiring of sensor 1 is safe. Am the one who was a problem with 99 accord eng light on. after replacing the up and down sensors by the shop(on base), it was fpund out by the honda dealer that sensor1 is still defective. so I went back to the shop and they finally found out that the sensor 1 wirings was not properly placed, so they did the re-wiring and put it again and the engine light came off quickly.
But after a day I picked up the car, I drove the car good so I'm okei going to post office. but when I started the car again to do my next errands, the gas starts to hesitate as I pump it. so i bring it back to hubby shop that day and they can't find nothing. they suspected that maybe there's moist on the gas since it was'nt been driven for a month.
I went home, and i tried to start it again, feels like the gas pedal is hard to push again and hesitating still and hear the noise on the break.. Did these thing has something to do after replacing the sensor?.
I hope i can received a response. Thanks.
Hopelessly w8ing,
salipoh2
Old Dec 21, 2008 | 03:41 PM
Default RE: is re-wiring of sensor 1 safe?
Your profile says Germany, so this is not the same car as a USA Accord. Still, lots of things are the same. But we need some more information about specifically what was done.
ORIGINAL: salipoh2
Sothe shop on basesaid the wiring was bad?
Did the Honda dealer not recognize this?
What EXACTLY was supposed to be wired wrong?
How did they know? (Honda wiring drawings? from where?)
What EXACTLY was changed?
ORIGINAL: salipoh2
Water in the fuel is possible, you can put fuel-dry product into gas tank. Usually its ethanol or methanol.
ORIGINAL: salipoh2
Does the gas pedal itself take more force from your foot? That would not be related to re-wiring the sensor.
Hesitating & stuttering can be the moisture in fuel, or might be from re-wiring the sensor. Hard to say until we know exactly what was changed.
ORIGINAL: salipoh2
Hopelessly w8ing,
salipoh2
Wemay need help from someone more familiar with wiring of European-spec Accords. I can try to guess what is the same, but not absolutely certain.
pondrun
Nov 8, 2021 09:40 AM
SilverCityAccord
Mar 4, 2008 08:57 PM
Bilal Khan
Feb 19, 2008 10:26 AM
Leonhartilly
Jan 18, 2006 11:49 AM
Chadd122
Jan 16, 2006 01:09 PM
