real time diagnosis needed
Old Jul 10, 2006 | 02:21 PM
Crusherdan
Default real time diagnosis needed
Coolant leaking on a 1995 Accord LX 2.2 ltr. auto trans.
I want to buy the car, but owner says he's putting in a half gallon of coolant every 9-10 days. (100 degrees here in north Texas right now)
Sounds like a minor issue, but experience tells me a coolant leak is never minor. He has had visual inspections and preasure tests and has been told they want to pull the head and check for cracks.
Any suggestions on possible solutions?
Old Jul 10, 2006 | 08:15 PM
Chiovnidca's Avatar
Default RE: real time diagnosis needed
ORIGINAL: Crusherdan
Look for a different car. Or be prepared to spend some money.
Old Jul 11, 2006 | 02:28 AM
Mike7311's Avatar
If you don't see the coolant leak or puddle under the engine, it's a blown head gasket. Check spark plugs for wetness. Overheating destroys engines so I'd pass on this one. A easy fix will only last 10-20K max.
Old Jul 11, 2006 | 11:34 PM
deserthonda's Avatar
first thing i would do i to pressure test the cooling system, including the radiator cap.. make sure there are no leaks.. if no leaks, make sure t-stat opens fine and fans work ok,,...if you find something wrong fix and retry,, if nothing wrong,, have a shop do a leakage test for possible blown head gasket, cracked head ..
Sunnysideup
Dec 24, 2012 05:38 AM
bluemagic03
Jan 20, 2008 02:15 PM
kriegz99
Jun 12, 2007 11:31 PM
Crusherdan
Jul 10, 2006 11:49 PM
EternalBuddha
Apr 16, 2006 09:34 AM
