real time 2.2ltr engine problem
Old Jul 10, 2006 | 12:34 PM
Crusherdan
Default real time 2.2ltr engine problem
On a 95 accord 2.2ltr, have a problem of the engine loosing coolant slowly. About a half gallon every week or so. No aparent leaks.
Is anyone aware of any common issues like this with this engine? Any issues with heads cracking or head gaskets blowing?
I had a head gasket blow in my land cruiser and found out is is a common problem. I'm not that familiar with the accord issues.
Thanks for your help.
Old Jul 10, 2006 | 01:36 PM
sir_nasty's Avatar
Default RE: real time 2.2ltr engine problem
Welcome to the forum! A couple of things on this... 1. it's not a common issue for any honda that I know of to blow head gaskets. 2. Have you checked your freeze plugs? that's an easy way to loose coolant slowly and then it just burns off on the engine... but there will still be a residue of some sort that gives it away... Also, any white smoke when you're taking off? Have you checked your oil (prior to running the car for the day) to see if there is any water in it? Does everything else on the car function normally?
Old Jul 10, 2006 | 02:09 PM
Crusherdan
Not really any other signs that I know of. The car seems to run fine. I'll look at the freeze plugs when I get it up on a rack.
Do you know where all the freeze plugs are on this engine?
Old Jul 10, 2006 | 09:47 PM
YeuEmMaiMai's Avatar
do the following
1. pull plugs and inspect them for signs of coolant.
2. do a pressure test when cold and make sure your system is holding at least 16lbs
3. Pressure test when hot.
Old Jul 10, 2006 | 11:49 PM
mbo1985's Avatar
Yeah, that white smoke is a tell tale sign of a head gasket gone bad. If you have white smoke after the car has warmed up, you'll definetly want to do a coolant pressure check and a cyl pressure / leak down test.
kaushik1
Apr 6, 2015 01:22 AM
haz
Nov 5, 2009 04:32 PM
92Inspire
Aug 13, 2006 03:37 PM
Crusherdan
Jul 11, 2006 11:34 PM
EternalBuddha
Apr 16, 2006 09:34 AM
