98 Honda Accord 2ltr Auto 4dr Door Actuator Problem
Old Apr 5, 2015 | 01:30 AM
kaushik1's Avatar
Default 98 Honda Accord 2ltr Auto 4dr Door Actuator Problem
Hi Every one, I am new to this forum. My daughter have a Honda Accord 2ltr Auto car. Its door lock of passenger side is some time lock but didn't unlock and driver side rear door lock is not even move. Only driver side lock and passenger side rear door lock is working perfectly ok with alarm key. Any sort help in form of pictures/videos for this problems is welcome. I am not an technical man. Thanking you in advance.
Kaushik.
Old Apr 5, 2015 | 04:04 AM
Welcome to HAF
Just so I'm clear.....the pass front and drivers rear door locks are not working. They will not work from the master switch or from the "key fob".
Old Apr 5, 2015 | 04:25 AM
kaushik1's Avatar
Hi poorman212, They will not work from both options. Thanks.
Old Apr 5, 2015 | 08:56 AM
Could be a couple of things....or multiple (one door has an issue with X and the other with Y).
First thing I would do is verify the actuator(s) are good. To do this you will need to remove the panel and apply 12v and ground to them. If you are willing to get in there I can dig up the wire diagram and get the wire colors.
Old Apr 5, 2015 | 06:57 PM
Welcome member..
I shall move this to where your now reading it at..
Thank you for posting..
Old Apr 6, 2015 | 01:22 AM
kaushik1's Avatar
Hi All, One more problem my daughter told about her car that a staring wheel while turning left its feel very hard but while turning right its feel very smooth and easy. Any suggestion in this regards. Thanks.
Doublel
Mar 11, 2013 07:57 AM
justvisiting
Jul 6, 2012 12:28 AM
haz
Nov 5, 2009 04:32 PM
Crusherdan
Jul 10, 2006 11:49 PM
94AcCoRd
Jun 29, 2006 05:23 PM
