rear brakes
Old Nov 7, 2008 | 07:38 PM
raheem34
Default rear brakes
Can anyone explain what type of brakes does and 06 accord has? and what kind of cost is it to change them, i have grinding noise when i apply brakes.
Old Nov 8, 2008 | 07:04 AM
Default RE: rear brakes
Nobody here is a mind-reader. Provide some details of vehicle; engine type, trim level. Place that info in your signature line and it's always presented when you post.
Old Nov 8, 2008 | 03:42 PM
jerrym's Avatar
Almost A Senior Member
Also your local auto parts store can tell you when you provide some info about the vehicle.
Brake pads (rotors), or brake shoes (drums) vary from about 15.00 to 50.00 depending on the brand you get.
Also hopefully you did not drive to long with the "grind" and there is no damage to the rotors/drums.
Old Nov 8, 2008 | 04:57 PM
DerekD
You should pick up a Haynes or Chiltons repair manual. Parts stores and Wal-Mart sell them or get a used one off eBay for cheap. They'll show pictures and instructions on how to repair your brakes. For cost, price brake shoes (for drum brakes) or pads (for disc brakes) at your local parts store or look them up on the store's website. If the shoe/pad worn into the drum/rotor you will either have to take the drum/rotor in to be turned (remachined) or you will have to replace it. If you have drum brakes in the rear you will probably need to replace the wheel seal too that keeps grease on the wheel bearings.
Derek
alphaney
Feb 12, 2022 10:14 AM
SC Tiger
Jul 11, 2011 09:15 PM
ZionsWrath
Jan 25, 2009 11:19 PM
Jcaleno
Apr 3, 2007 10:34 PM
thunder_x
Sep 27, 2006 11:00 PM
