Rear disc brake question
Old Mar 12, 2010 | 11:19 PM
mamtsberg's Avatar
Default Rear disc brake question
I need to replace brake pads/rotors front and back on a 2001 Accord 5 speed. Questions:
1 - are the rotors the same on the front/back? I'm assuming not but I'm trying to find them online (I use Rockauto) and can't find a difference from front/back.
2 - this will be the first time I changed the rear brakes, is there anything special I need to know about getting the rotor off/on, any nuts that need replacing when I do the job, etc..
Thanks for any help.
Old Mar 13, 2010 | 03:10 AM
I would look at the part numbers at rock auto. It looks like they have different part numbers for a 2001 EX.
Front ones are likely vented and the rear ones probably are not.
Old Mar 13, 2010 | 11:58 AM
I've NEVER seen ANY car that uses the same disks front & rear.
On the rear, you can't push the piston straight in like in front. There's a slot across the face of the piston. Use a really wide screwdrive or a putty knife or something like that to TWIST the piston like you're screwing it in. That's the handbrake auto-adjust mechanism & you'll break it if you push it straight in with a C-clamp.
jrzwalker86
Dec 5, 2011 06:49 PM
Andy2k9
May 15, 2010 05:31 PM
sirgilligan
Dec 22, 2008 10:47 PM
BlkCurrantKord
Apr 27, 2008 09:27 PM
KevinAccord
May 21, 2007 01:59 PM
