Rear disc brake swap 94 accord
Old Sep 22, 2009 | 09:28 PM
jesselap's Avatar
Default Rear disc brake swap 94 accord
Hi,
Just curious on how involved it would be to convert my rear drum brakes to disc brakes on my 1994 honda accord coupe. If anyone has any idea's, or comments on if this is even worth it, please let me know
Old Sep 22, 2009 | 09:48 PM
Its probably not worth it.
You would definitely need a caliper, brake pads, rotor. The knuckle/hub from an EX from a junkyard, I think.
I'm not sure if the e-brake or the hydraulic lines are the same between the EX vs the LX/DX. You would have to go to a parts web site and see what part numbers are the identical between your accord and the EX accord to eliminate the parts you would need to buy.
Old Sep 23, 2009 | 07:17 AM
I think the wheelbearing/hub is the same, but the knuckle is different. Probably the spindle is different.
I'm pretty sure the handbrake cables and the hydraulic tubes are different.
If you're lucky the suspension control arms are the same??
If you have ABS, the wheel-sensors might be different?
Old Sep 23, 2009 | 07:56 PM
jesselap's Avatar
Thanks,
All I needed to know. I don't think it would be worth my time
jrzwalker86
Dec 5, 2011 06:49 PM
sean
Jul 19, 2011 12:31 PM
Andy2k9
May 15, 2010 05:31 PM
sirgilligan
Dec 22, 2008 10:47 PM
KevinAccord
May 21, 2007 01:59 PM
