REAR DOOR PANEL REMOVAL 90 ACCORD LX
Old Sep 28, 2006 | 11:45 AM
RBG
Default REAR DOOR PANEL REMOVAL 90 ACCORD LX
I have it almost undone. I have pull from the bottom and popped all the plastic clips, I have removed the screw from the arm rest and the one in the door handle pull cup. The whole panel seems to loose. I can move/rock it but it seems to be attached right behind the door latch/pull cup mechanism. Any ideas???
THANKS!!!
Old Sep 28, 2006 | 12:29 PM
deserthonda's Avatar
Default RE: REAR DOOR PANEL REMOVAL 90 ACCORD LX
if you look where you removed the inner door handle out of, there is another screw in there , it is a bigger screw going at an angle
do not pull on panel till that screw is removed or you will brake it
Old Sep 28, 2006 | 12:58 PM
RBG
Ok I have the paneloff and I am now trying to get the window free from the track So I can take out the bar that the cables ride around and the motor to see what's wrong. The window is stuck so It won't close all the way. I am trying to free the window from the track. I have the motor loose and the bar loose to remove but I can't get the window loose. Any suggestions?? THANKS
Old Sep 28, 2006 | 01:48 PM
hondadude's Avatar
At the bottom of the glass there are 2 glued on brackets, they have 10mm bolts that hold the glass to the bar that raises the window.
Old Sep 29, 2006 | 01:29 AM
what's wrong is that you need a reg/motor assembly........DO NOT get it from Honda it is about 300 dollars .. get an aftermarket for about 100-125 dollars ..
remove the 2, 10mm bolts like Dude said, raise the window up and tape it up so it won't slide down while you replace the regulator/motor assembly
Old Sep 29, 2006 | 05:33 PM
sir_nasty's Avatar
or you can get one from where I got mine.... I had a GREAT experience with them and saved myself a decent amount of cash...
http://www.1aauto.com/1A/WindowRegul...1331435/407011
humblehyper
Dec 17, 2009 02:59 PM
Electron Man
Mar 13, 2007 02:02 PM
RBG
Sep 28, 2006 12:30 PM
RBG
Sep 28, 2006 11:31 AM
zerodoubt
Jun 22, 2006 08:15 PM
