REAR DOOR PANEL REMOVAL 90 ACCORD LX
I have it almost undone. I have pull from the bottom and popped all the plastic clips, I have removed the screw from the arm rest and the one in the door handle pull cup. The whole panel seems to loose. I can move/rock it but it seems to be attached right behind the door latch/pull cup mechanism. Any ideas???
THANKS!!!
THANKS!!!
if you look where you removed the inner door handle out of, there is another screw in there , it is a bigger screw going at an angle
do not pull on panel till that screw is removed or you will brake it
Ok I have the paneloff and I am now trying to get the window free from the track So I can take out the bar that the cables ride around and the motor to see what's wrong. The window is stuck so It won't close all the way. I am trying to free the window from the track. I have the motor loose and the bar loose to remove but I can't get the window loose. Any suggestions?? THANKS
what's wrong is that you need a reg/motor assembly........DO NOT get it from Honda it is about 300 dollars .. get an aftermarket for about 100-125 dollars ..
remove the 2, 10mm bolts like Dude said, raise the window up and tape it up so it won't slide down while you replace the regulator/motor assembly
or you can get one from where I got mine.... I had a GREAT experience with them and saved myself a decent amount of cash...
http://www.1aauto.com/1A/WindowRegul...1331435/407011
