rear door unlock problem
Old Jul 8, 2012 | 11:15 PM
hookup11's Avatar
Default rear door unlock problem
i havve a 97 honda accord and just bought and successfully installed a keyless entry with automatic starter. Everything worked perfectly fine for one month, and now the keyless entry opens/closes all doors but the back rear. It also makes a grinding/humming sound each time i activate the door lock/unlock feature for a couple of seconds....is it possible there is some sort of motor burned out and if so is it an easy fix..thanks guys...
Old Jul 8, 2012 | 11:16 PM
hookup11's Avatar
back left door,,,humming sound is coming from that door...
Old Jul 9, 2012 | 07:42 PM
Do you get the same result using the lock/unlock in the car? I would test the lock actuator and then double check the install.
Old Jul 10, 2012 | 06:50 PM
hookup11's Avatar
Default lock/unlock
yes i do get the same results when i press unlock/lock inside the car...how do you test actuator...
Old Jul 10, 2012 | 09:39 PM
jordan925's Avatar
I have a similar issue. I bought my car used and my rear passenger door lock doesn't work. I can manually pull it up and down but with the switch or remote it just moves slightly for a second but doesn't go all the way.
Old Jul 10, 2012 | 10:11 PM
The door lock actuator is a common problem on accords.
Here is a post from a mod on here from the HondaTech site for a DIY repair. This is for the front actuator, but the rear should be similar.
94-97 Accord D.S. Lock Actuator - Microswitch Repair/Reset? - Honda-Tech
Old Jul 10, 2012 | 10:20 PM
To test the actuator, refer to post #6 of this thread:
https://www.hondaaccordforum.com/for...ctuator-36689/
This is the new DIY condensed repair guide I made for this forum a couple of days ago:
https://www.hondaaccordforum.com/for...cycling-48713/
jza240sx
Apr 30, 2013 04:14 PM
jalfonsetti
Aug 10, 2009 10:44 PM
sharky06
Jul 9, 2009 01:07 PM
PootsworthIII
Dec 30, 2007 01:12 AM
