Rear Door Windows..Can I get them to go lower?
Old May 17, 2012 | 06:14 PM
96FiveSpeed's Avatar
Default Rear Door Windows..Can I get them to go lower?
Im not sure if it is a child safety issue,but both rear door windows do not go fully down.Just past halfway down they stop.Is there a stop or bracket inside the door I can remove so I can let the window go down to the bottom?
I was going to take the door panel off and have a look,but do not want to remove it unless someone knows for sure.I hate cracking the small plastic parts on the old door panels.
Old May 17, 2012 | 06:18 PM
crispin's Avatar
You should put the year honda in your signature.
Based on your user name I am going to guess you have a 96
I have a 97 mine go down just past 1/2 way down.
This is a design of the car and cannot be changed.
Old May 17, 2012 | 06:26 PM
Thanks...I cant imagine it cannot be modded to go lower.Is it because the door is narrow inside?
Hmmm..Im one of those that never say never with cars.
Yes I have a 96 5 speed and I will also add it to my signature.
Old May 17, 2012 | 06:35 PM
It is by design.
If you try modifying, you may be restricted by the travel of the window regulators. The rear regulator are somewhat shorter in length compared to the fronts.
Even the newest Accord sedan rear windows do not go all the way down.
Attached Thumbnails Rear Door Windows..Can I get them to go lower?-window-regulator.jpg
Old May 17, 2012 | 09:54 PM
Roader's Avatar
Note the dogleg on the bottom of the back doors to accommodate the rear wheel wells.
Old May 17, 2012 | 10:44 PM
GoneHonda's Avatar
we own a new Toyota Corolla and the rears go all the way down
Old May 21, 2012 | 02:43 PM
Thanks for the replies all.Im going to leave it alone as is.
Edd Welch
Apr 9, 2013 06:29 PM
Nitehawk Girl
May 13, 2012 08:21 PM
rpreziosi
Jan 18, 2010 07:11 AM
shaleck
May 14, 2007 08:59 AM
