Rear strut bolt - will home depot bolt work instead?
Old Oct 6, 2019 | 08:15 PM
2hisOwnAccord's Avatar
Default Rear strut bolt - will home depot bolt work instead?
I have a 99 Honda Accord and the rear strut bolt broke. my Honda dealer was closed today and I wanted to know if I could instead use a high grade home Depot zinc plated bolt of similar size?
This bolt connects the rear strut to the lower arm
This one: https://www.homedepot.com/p/Everbilt...9338/205037812
Instead of: https://www.hondapartsnow.com/genuin...2-s84-a00.html
Old Oct 6, 2019 | 08:18 PM
Greyaccord's Avatar
Humm..in my view... Do what you have to, but get the OEM Honda bolt in there as soon as you can.
Old Oct 7, 2019 | 12:18 PM
Default Which nut to use for rear strut- bolt broke
I'm going with the Honda screw. I had a problem where my bolt actually broke off and the nut is supposed to be welded to the lower arm so now I'm trying to figure out if I should use another Honda nut, I have a few extra nuts hoping that'll work okay instead any advice?
The nut that broke off from lower suspension arm I'm pointing to. Other nut options I have are pictures. The screw broke pictures there too which holds the rear strut to the frame.
Nut that broke off from spot on rear strut and lower arm. I need a replacement option. Any advice? Will other nuts work? 10mm
Old Oct 7, 2019 | 01:59 PM
It looks like I will just purchase a whole replacement arm part from Honda which is about $27. This has the bolt on there and will work for me.
Mar 4, 2010 01:07 AM
Rodders
Mar 21, 2009 04:36 PM
dreamweave12
Mar 17, 2008 04:18 PM
dreamweave12
Mar 16, 2008 01:45 PM
wsavt213
Jun 18, 2007 08:45 AM
