rear wheel bearing
Old Feb 27, 2007 | 06:26 PM
dgiff
Default rear wheel bearing
I own a 2001 accord ex v6 4dr 4disc brks. I have the tell tale hum or buzz you get from a bad wheel bearing in the rear. The replacement part is rather cheap . Does anyone now how difficult the job is?I would much rather do it myself, as long as special tools and 10hrs of labor aren't involved.
Old Feb 27, 2007 | 06:57 PM
RSM93HONDA's Avatar
Default RE: rear wheel bearing
I believe that the bearing has to be pressed. It wouldnt take long to remove and have someone press a new bearing in. I had my mechanic put a new rear bearing in my car. It cost about 150 parts and labor. Hope this helps. Thanks.
Old Feb 27, 2007 | 08:07 PM
hondadude's Avatar
Very easy job, the replacement bearing comes as an assembly, Remove the brake caliper, remove the rotor, pop off the center cap, remove the 32mm spindle nut.
So jack, jack stand, 32mm impact socket, Good 1/2" breaker bar,hand impact driver with #2 phillips bit, [for removing rotor] 12mm&14mm wrenches and sockets.
[IMG]local://upfiles/5417/53E7D259841048B5910814D8E3BDBA9A.gif[/IMG]
Old Feb 27, 2007 | 09:43 PM
dgiff
Thanx hondadude that was xactly what i was hoping for!! looks like an hr job.
joenintiesc
Apr 14, 2013 07:29 AM
ScottSoSlick
Mar 18, 2009 03:28 PM
oma93
Feb 6, 2008 12:43 AM
cclingma
Jan 28, 2008 11:29 PM
regan513
Mar 13, 2007 07:44 PM
