Release Bearing
Old Mar 21, 2008 | 10:24 PM
tambler
Default Release Bearing
2000 Accord, 5 speed 4 cyl.
I have the chirp of a release bearing while my engine is idling. The clutch and bearing are new(ish) (25,000 km), what is going to happen if I ignore the chirp? I've noticed that in the last month or so the chirp has graduated to a whirring noise when the clutch is lightly depressed.
If the answer is to tear it apart and replace the bearing, do I change the whole clutch assembly... resurface the flywheel????
Old Mar 21, 2008 | 11:21 PM
Chiovnidca's Avatar
Default RE: Release Bearing
I had a really bad one in the shop a while back that wore through the pressure plate arms. You can replace just the bearing.
civilfox
Oct 15, 2023 01:49 PM
joenintiesc
Apr 14, 2013 07:29 AM
oma93
Feb 6, 2008 12:43 AM
footy14
Aug 24, 2006 12:33 AM
