Removing Rocker Arm Assembly
Just read the DIY for replacing lower rocker arm seals. I was planning on removing the the rocker arm asmbly while leaving the distributor on (I'll just remove the top bolt) and leaving the timing belt in place as well. Do I have to have someone hold down the distributor-side of the camshaft to keep it from popping up????
(F22a motor, auto tranny)
