Replaced master, bled, still poor brake pedal
Old Apr 19, 2012 | 05:07 AM
joec44's Avatar
This may help 1 take thw car out and make the ABS work Try to make wheels lock up do it 3 times the valves in ABS may be hung up this may fix that 2 I have also seen ware pads ware funney and all the pressure is used up trying to flaten the pads to the roters
Old Apr 25, 2012 | 10:18 AM
Dino3DAudio's Avatar
I am having the same issues with my 01 Accord EX. Replaced the master 3 times, bleed the brakes every 3-4 months, pedal feels like mush and if I need to stop quickly, the car feels like the road is icy by swaying a bit in the front. Two separate shops tell me they have no idea why this is happening. Any help guys?
Old Apr 26, 2012 | 12:02 PM
Did you bleed the brakes? Shop did it? Did you bench-bleed the master before putting it in?
Sometimes I've had the brake fluid come out clear (no bubbles) for awhile, but if I keep bleeding longer I finally get some bubbles then it's OK.
Old Apr 27, 2012 | 10:56 AM
Yes the shop did all the work. I have had the car to two separate shops and they still have no idea why air keeps entering the system.
I get bubbles out of the pass side front only right away when bleeding. A friend who works on cars claims it could be a leaky caliper, but I have seen no fluid on driveway or on inside of tire.
Old Apr 27, 2012 | 09:20 PM
Brake fluid can leak past the piston seals in the master. It would leak into the vacuum-booster, takes a long time to fill up before it leaks OUT. But in that case you would lose fluid inventory from the reservoir. See any loss of fluid?
Old Apr 28, 2012 | 08:24 PM
no loss of fluid at all.
gdimattia
Nov 30, 2014 09:02 PM
PJ_STYLES_95AccordEx
Nov 2, 2014 08:45 AM
tiredredcoupe
Nov 13, 2009 06:17 PM
nafango2
Jul 7, 2008 09:19 AM
Hondapt
Sep 19, 2007 11:30 AM
