Replacing 1997 Accord DX distributor rotor
Old Feb 5, 2020 | 06:08 AM
  #21
Seanjordan20's Avatar
It looks like they are differentiating by Hitachi or TEC. Most I've seen says does not fit Hitachi or for TEC only. I've only seen a few that says for Hitachi.
Old Feb 5, 2020 | 04:51 PM
  #22
The Toecutter's Avatar
Originally Posted by slobjones
Toecutter:
I'm thoroughly confused at this point. Do I have a TEC distributor, or not? Remember, the distributor cap I just replaced has "TEC" stamped on it.
This thread (https://www.hondaaccordforum.com/for...erences-58861/) indicates: "94-97 LX, DX with TEC Distributor: Rotor 30103-P08-003".
I searched hondapartsnow.com by my car's VIN and the site indicated I should order part No. 30103-P08-003. I've ordered that part via Amazon.
A VIN search also shows my car as: 1997 Honda Accord 4 Cylinders 2.2L MFI SOHC
Here's a diagram showing the TEC distributor: https://www.hondapartsnow.com/genuin...3-p08-003.html. Is this my distributor, or not?
For additional reference, here's the Hitachi distributor: https://estore.honda.com/honda/parts...&b=E++0510&dl=
At this point, going off the links I'd say you have a TEC distributor. I say that, because looking at the drawings the Hitachi has the coil built into it, and you can see the cap doesn't have a pole for a separate coil wire to attach to (built into the cap).
As to the fit or no fit, it might be a manufacturers fault (made wrong).
Old Feb 8, 2020 | 05:37 PM
  #23
slobjones's Avatar
Thanks to all for your help. The OEM distributor rotor (Honda Part #30103-P08-003) fit (where the after-market BWD Part #D712P did not), and the job is complete.
I replaced the distributor rotor screw with a 5mm-.80 x 10mm coarse hex cap screw. If you're working on a '97 Accord DX, file that information for future reference!
I'll attach pictures of the old vs. new Honda distributor rotors and the hex cap screw vs. original screw.
CD7jay
South
Dec 16, 2010 06:51 AM
diceallion
Aug 31, 2010 05:04 PM
ROLO
Aug 5, 2009 03:30 PM
95k
Oct 19, 2008 02:32 PM
MacLeod
Sep 16, 2007 08:01 PM
