Reverse Gear Wiring?
Old Mar 24, 2015 | 10:38 AM
  #31
fanta's Avatar
Last question, how should I ground the negative wire in the dashboard receiver, Monitor, and rear view camera?
Old Mar 24, 2015 | 11:32 AM
  #32
The ground wires can be attached to a bolt on the car's such as a bracket, etc. Usually you can use an existing bolt under the dash area; or if there is a hole already in a metal bracket use a bolt and nut to secure the ground wires with a ring terminal connector.
Old Mar 24, 2015 | 01:16 PM
  #33
fanta's Avatar
Where is the under dash fuse box? I got the add a circuit but am unsure where exactly to plug it in? Thanks!
Old Mar 24, 2015 | 01:24 PM
  #34
It is behind the driver's side kick panel. See post #9 link. There is a small access door for the fuses on the kick panel or if you need more room, the kick panel can be removed.
Old Mar 24, 2015 | 01:43 PM
  #35
fanta's Avatar
I stripped and attached the green wire for the receiver, now I am still confused where to add the add-a-circuit. Is it supposed to click in somewhere or do I need to hold it there with tape?
  #36
fanta's Avatar
Here's two pictures
http://imgur.com/pHNIo4X
http://imgur.com/VVhvGlK
Old Mar 24, 2015 | 01:59 PM
  #37
fanta's Avatar
Found it, it was hiding in plain sight.
http://imgur.com/wOPqorP
Which do i plug it into? Thanks
Old Mar 24, 2015 | 02:32 PM
  #38
The fuse box lid should say the numbers. I previously listed the unused slots for all models. On your car, you have even more due to the trim level not being fully equipped as some of model trim levels.
See attached picture. These should have power with the ignition in ON or START.
Old Mar 24, 2015 | 03:59 PM
  #39
fanta's Avatar
The receiver and transmitter work fine however, I tried using the two open ports (29/31) and that did not power the monitor on. I then tried using port 7 which is the back up port and that failed as well. Unsure why or what to do from here.
Pictures:
http://imgur.com/Rjy68cN,aKtwyF5
Old Mar 24, 2015 | 04:07 PM
  #40
Try a used fuse slot to piggy-back off of. Read the littelfuse instructions regarding how to piggyback a used fuse slot.
