Revving problem
Old Dec 13, 2012 | 08:39 AM
corey246's Avatar
Default Revving problem
Okay guys so I have a honda accord 95 ex. 2.2 vtec. I recently replaced the engine. I replaced it with the same engine. Same year and all. I took it for a drive and it seems to be in limp mode. It wont rev past 3500 rpms. CEL on.
I pulled the cel code and i got code 4. Crank angle. I did an ohms test of the sensor and its within spec. Whats next?
Old Dec 13, 2012 | 10:25 AM
Silver6gen's Avatar
On my car the crank angle is figured out using three sensors, Crank position sensor, a sensor on the cam and one other one I can't remember. Granted this is on an OBD-II car.
So hmm, I would suggest testing the alternator first.
Old Dec 13, 2012 | 02:34 PM
The scheme of timing sensors changed a lot between OBD-1 vs. OBD-2. In 1995 it was all 3 sensors inside the distributor (CKP, CYP, & TDC). Code 4 is CKP sensor.
Check the wiring harness plug at the distributor. Loose/dirty/corroded?
Look inside the distributor. Red dust indicates a bad distributor shaft bearing, but it also might get that dust in around the magnetic sensors to mess em up.
1990accordex
May 29, 2013 06:41 PM
zairas
Nov 21, 2008 11:47 PM
cmm
Jun 14, 2008 09:40 AM
dricker
Mar 23, 2005 04:37 AM
