Rough Idling
Old Mar 8, 2012 | 02:50 PM
LezPez's Avatar
Default Rough Idling
Well, I'm back here again.
This time my issue is rough idling. This didn't start till a day after I cleaned out the EGR Ports to fix the P0401 code.
Though I think I might have an idea what the issue is but I'm posting to make sure.
When I was trying to get the EGR off (and failed since one of the nuts got stripped) I got the "clever" idea to move the Throttle Body a bit to try to get the nut off.
I unscrewed the nuts from the TB and lifted it up and moved it a bit to the side. This was probably the huge mistake I did. I heard the gasket move around a bit but regretting the idea I put the TB back.
After that day I haven't had time to myself and try to solve the issue until today.
I used the search function for a guide on how to remove the Throttle Body for cleaning but to no avail. ):
If someone knows can you please link me to the guide or post step by step how to do it? I would really appreciate it. That's the last time I try one of my "clever" ideas that ended up being stupid mistakes.
Old Mar 8, 2012 | 06:11 PM
You may want to reset the ECU by pulling the 7.5 amp backup/radio fuse in the engine bay fuse box. That solved a rough idle when I messed with my throttle body on my 95 accord.
Old Mar 8, 2012 | 06:30 PM
LezPez's Avatar
I'll try that then.
Also, I realized that I goofed, I didn't tighten the nuts on the TB all the way.
That probably didn't help at all.
stubs
Jan 18, 2012 01:42 AM
abeyphilip
Oct 13, 2011 08:19 PM
techjohnny
Oct 7, 2010 04:20 PM
kc0jsj
Feb 22, 2010 08:42 PM
gtg162y
Jan 2, 2009 10:55 AM
