Rough start issue. Need help
Old Sep 25, 2007 | 08:31 AM
  #21
falkore24's Avatar
Default RE: Rough start issue. Need help
That's the reason ..... what I meant is that I put in the Marvel when I have 1000 miles left on my oil change. Since you don't think that you have the right oil in, you basically already need a change. In your case, I'd drain 2-3 filters worth of oil and add the Marvel, drive for 1000 miles and get the gunk that's cleaned as well as the 10w30 out of the engine. Just before the oil change I'd also flush the engine .... refill with 5w20 and know that your crankcase is clean and has the correct oil. If you are real nervous about the heavy oil, change the oil twice at the end. This will ensure that all cleaners and old oil are removed.
Old Sep 27, 2007 | 03:29 AM
  #22
rtmobile96's Avatar
Good deal. I don't know if I'll be able to get the engine flushed right now due to monet reasons. But I'll go ahead and add the Marvel and do the oil change anyways I guess. I'm also ganna check all the spark system. Thanks.
Old Sep 27, 2007 | 07:38 AM
  #23
falkore24's Avatar
The last time I flushed the engine, it cost $8 for a can of Gunk engine flush. All you have to do is pour it into the oil fill when you drop the car off for the oil change, run the car for 15-20 min. and leave so the shop can do the oil change. Tell them that the flush is in there so they minimize how much the car is moved and they might also want to let the car cool for a half hour to let the oil cool down a bit.
Old Sep 28, 2007 | 08:26 PM
  #24
rtmobile96's Avatar
So what if I'm changing the oil. I never take my cars to get the oil changed. I do all my own maintanence. Is it just poor the engine flush in, run it for about 20 min., let it cool down, then change the oil? When I had my car flushed, I actually had my buddies lube shop due it, I never thought to look for do it yourself stuff off the shelf.
Viets90
Aug 19, 2013 11:48 AM
fdsa487
Feb 5, 2013 04:55 PM
bpethomas
Jun 5, 2012 10:47 AM
bkearney
Mar 15, 2012 06:40 PM
bradleyt86@live.com
Aug 5, 2011 06:30 PM
