rpm bouncing
Old Oct 22, 2009 | 07:12 AM
Check to see how little you need to turn your key to shut off the engine. Can you make it quit by wiggling the key? Many times a flaky ignition switch can kill the engine with just a tiny turn.
Old Oct 23, 2009 | 12:47 PM
o CRA5H o's Avatar
ok, i did the wiggle the key thing and it didnt turn off. i had to turn the key all the way to turn the car off. it does have keyless entry on the car its a remote that has honda on it so i know there is a security system on it but i think its stock cuz nothing has been to to the car, its all pretty much stock. would it make a difference if there is no radio in the car?
Old Oct 26, 2009 | 07:08 AM
I haven't had a factory security system screw up like that, so I don't know...? (but I'm no expert on that stuff)
Check (to rule out) for dirty/corroded/loose battery cables, especially the opposite end not at the battery. Don't forget to check where the actual cable is crimped into the end connectors.
SlyBlackDragon
Jan 6, 2012 10:13 PM
mrquettfan
Nov 24, 2010 01:02 AM
davisi
Aug 22, 2010 04:26 PM
nitro74d
Feb 2, 2007 04:47 PM
nitro74d
Feb 2, 2007 03:23 PM
