(S) light in dash flashing
Old Jun 27, 2013 | 04:15 AM
ruaphuNZ's Avatar
Question (S) light in dash flashing
HI All,
Our 92 Accord has starting playing up. THe sport light for the gearbox has started flashing in the dash area. Have also noticed the car will now not change gears properly since light has started flashing?? Seems to only select first and fourth (and OD too). I can manually select gears and runs as per mechanically, but just not shift if left in auto.
I suspect the issue is purely electronic. Do these boxes have a stand alone electronics section that controls everything?? if so where is it and what does it look like.
Oh, oil is full and nice and red, no signs of burning or blackening.
Any advice, pointers, actions to rake etc on what the issue is would be great.
Cheers Andrew
Old Jun 27, 2013 | 07:19 AM
The "S" lamp is like the engine-malfunction lamp but for the transmission. You check for error codes the same way (jumper the SCS connector) but it's the "S" lamp that flashes out a code instead of (or in addition to) the MIL.
Old Jun 27, 2013 | 11:37 AM
kellysa111's Avatar
don't know about 92's but my 91 had the S flashing and my mechanic changed the gear shift thing and its worked since.
Old Jun 28, 2013 | 06:00 AM
There's quite a few things that can cause the S lamp to flash. Best to read the error code so you can narrow it down.
Punisher1
Jun 7, 2015 05:57 PM
Chilli
Jan 17, 2014 07:45 AM
Devil Strider
May 31, 2012 09:21 PM
sunshinegirl7681
Jan 30, 2012 05:09 PM
aey51305
Sep 25, 2010 06:12 PM
