Seal Removal
Old Sep 11, 2008 | 01:09 PM
sqrly_zx3
Default Seal Removal
I have a 94 accord with the sohc non vtec and I was wondering how do you go about removing the camshaft seal the balance shaft seal (I also have the retainer) and the crankshaft seal (right behind the the pulley. Any and all help will be appreciated.Thanks alot
Old Sep 11, 2008 | 01:59 PM
falkore24's Avatar
Default RE: Seal Removal
I think this was asked yesterday. Please search prior to posting a new thread.
Thank you!!
Old Sep 11, 2008 | 02:38 PM
Search function doesn't work. I tried.
I have not personally removed any seals, but what I have heard from others is use of small sharp screwdriver, long wood screw/s screwed into seal, oring pick, or other tool to pry or pull the seal out. Care must be taken to avoid scratching the sealing surfaces.
I like the idea of two screws on opposite sides to gradually pull the seal out, but again I haven't done this.
FWIW, I think removal of a non-leaking seal may is questionable. You are asking to create a problem. These are not a maintenance item to my knowledge.
Old Sep 11, 2008 | 02:42 PM
falkore24's Avatar
Finch has a working search .... he is #10 on the top 10 posters list
Old Sep 11, 2008 | 02:47 PM
Not sure your meaning. I simply meant my search function doesn't work and perhaps the original posters doesn't either.
regards
Old Sep 11, 2008 | 03:11 PM
falkore24's Avatar
I understand what you meant .... what I'm saying is that finch created a temporary search for members to use that actually does work. There is a link to it in his profile.
Finch's search
bigeyedphish
Jun 24, 2014 05:46 PM
nixalot
Jan 25, 2007 02:02 PM
brave_mhy
Jul 29, 2006 02:36 AM
lightshow
Jan 16, 2006 10:56 PM
