Sealing bleeder screw threads
Old Mar 8, 2016 | 11:03 AM
BlackLX4's Avatar
Default Sealing bleeder screw threads
Is there a good, safe way to seal bleeder screw threads for vacuum bleeding? I tried vacuum bleeding for the first time yesterday and I love it, except for all the air getting pulled past the threads.
Old Mar 8, 2016 | 03:31 PM
The bubbles enter and leave the bleeder. They don't flow "upsteam" into the caliper. Don't worry about bubbles!
Old Mar 8, 2016 | 03:35 PM
That's exactly why I eventually bought a pressure bleeder.
The best I've been able to do with a vacuum bleeder, is to put a nice bead of grease all around the base of the bleed valve where it screws into the caliper body. It's pretty easy to miss a spot with the grease, and have it leak anyway. You have to kind of smear or push the grease down into the corner between the bleed valve & the caliper body.
What Texas says is true if you're flushing the system and there isn't any air in there to start with. I got frustrated with the bubbles when I was trying to decide when I had gotten all the air out of the system.
Old Mar 8, 2016 | 09:30 PM
BlackLX4's Avatar
Then how are supposed to know when all of the air in the lines is actually out, should there be any in the lines?
Old Mar 9, 2016 | 08:19 AM
Bubbles in caliper cause slugs of air. Only rarely is it necessary to bleed air; caliper or hose replacement. I only have bled for fluid replacement.
500$accord
Dec 16, 2011 08:22 AM
pinky0519
Jan 12, 2010 07:01 AM
Rainy
Sep 29, 2009 05:26 PM
1996AccordLX
May 16, 2007 09:18 AM
chibiko
Apr 12, 2007 02:53 PM
