seat help
Old Dec 29, 2007 | 02:59 PM
figherace66's Avatar
Default seat help
after getting my seats fixed for some tears in them i noticed my drivers seat rocks back and forth a bit an inch or so. I'm wondering is this normal or are there some bolts i need to tighten down?
Old Dec 29, 2007 | 03:02 PM
sir_nasty's Avatar
Default RE: seat help
sounds like a bolt's loose, there should be one on each corner of the seat, if it rocks really easily you may be able to figure out which ones are loose with your fingers
Old Dec 30, 2007 | 01:27 AM
HondatechAV6's Avatar
list stated - could be loose seat bolts. i've done it once..heh...
however, what year?
certain years have a defect in teh seat track - a bushing in the height mechanism fails and the seat rocks.
Old Dec 30, 2007 | 02:07 PM
its a 98 EX-L
Old Dec 30, 2007 | 10:10 PM
you might have a lifetime warranty on the seat height bushing/support kit, but i need your vin number to look it up.
did you check if the four bolts holding the seat to the car were tight?
does it feel only like a front to back looseness or side to side looseness?
Old Jan 1, 2008 | 11:43 AM
the main bolts holding the seat are tight, and the rocking is only front to back, all the seat adjustments work fine, i can move the seat where i want it to. i'll get you my vin number later when i dig my car out of the snow. and is the lifetime warranty covering multiple owners? beacue as far as i know im the second owner.
Old Jan 1, 2008 | 12:42 PM
it should be, it all depends if your VIN is covered. otherwise you can buy the parts for probably $30 and do it on your own with instructions if you want.
Old Jan 1, 2008 | 01:08 PM
if i get around to taking the seat out, will i be able to clearly tell if soemthing is broken, and also by not doing anything am i causing more damage to it?
Old Jan 1, 2008 | 06:22 PM
you won't see it, it's a bushing. you'll need to remove a few nuts to find the bushings. they are form fitted, so only new replacement bushings will fit it. the rocking shouldn't be all that bad, just noticeable seat movement when braking or accelerating. if it's worse than that you might find something broken underneath.
JOE.G
Nov 4, 2012 08:48 AM
Johnny Racer
Sep 13, 2012 07:43 PM
MysticBlueEX
Feb 18, 2011 06:55 AM
mamtsberg
Mar 17, 2010 09:15 PM
lacrw
Aug 1, 2007 08:43 AM
