Setting base idle question
Old Mar 18, 2013 | 07:34 PM
notoriousganstr's Avatar
Default Setting base idle question
In reference to this thread:
https://www.hondaaccordforum.com/for...e-speed-38734/
when i do this ,after unplugging the iacv the lowest i could set my rpms is 900 is that normal?
Old Mar 18, 2013 | 07:41 PM
I created a new thread from your post and moved it to the General Tech Help section.
Please do not post help questions in the DIY section.
Old Mar 18, 2013 | 07:49 PM
No, this means you have an air leak somewhere; vacuum lines, PCV, brake vacuum booster, etc. Spray throttle body cleaner around w/ engine idling and listen for a change in idle.
Have you thoroughly cleaned IACV, throttle plate, and throttle bore? If not, try that first.
You should also check that throttle plate is fully closing when on idle stop. If someone ignorantly adjusted throttle plate, idle stop screw the base idle can't be achieved.
Old Mar 18, 2013 | 08:09 PM
Or (worse yet) someone may have used the throttle cable to adjust idle. In that base-idle post there's a list of things for you to check & fix first, like vacuum leaks & throttle closing.
Have you done any other work? Intake manifold removal where the gasket might not seal? Fuel injector O-rings where they go into the manifold?
Old Mar 19, 2013 | 09:54 AM
Ok, I did clean the above method, I also did take apart the intake (I did a head job) I used the same seal but when I spray carb cleaner all around the intake I get no changes to the idle, I did just continue eith the instructions anyways and car was idling perfect but ss soon as I gave it gas it just shutoff, so I adjusted the idle screw 2 turns and now its idling almost perfect. ? Should I still be worried about it?
Old Mar 19, 2013 | 12:11 PM
If idle speed is 700-800 rpm, then you should be fine.
JimBlake
DIY Answers.
15
Jul 22, 2021 02:11 PM
falkore24
Aug 30, 2011 01:23 PM
piggylover1985
Jun 7, 2011 09:01 PM
Philthy
Mar 14, 2007 03:47 PM
beaterhonda
Jan 6, 2007 10:40 PM
