Several Codes / car hesitates
Old Oct 19, 2012 | 01:30 PM
Jet sitter's Avatar
Default Several Codes / car hesitates
I started my 4 cylinder 2000 Accord this morning, no problem. Drove on the highway 70 MPH, no problem. Exited the highway and the car began to buck/hesitate. The check engine light came on, so I took it to Autozone. They found the following codes;
P1399 Misfire - distributor code
P0301 - Cylinder 1
P0302 - Cylinder 2
PO303 - Cylinder 3
P0300B - EGR
No issues with Cylinder 4. I removed/replaced the plugs, improved the idle rpm from 700 to 900. (still skips under load) Now I'm looking at changing out the EGR valve, or do you think I can get by with just cleaning it?
Old Oct 19, 2012 | 02:01 PM
Lightbulb Hi Member
Causes : Injector fault
: Vacume Leak
: Low or High Fuel Pressure
: Wires,Coil and Plugs
These are your codes problems..start checking from here..
Hope you get it back to normal...
Old Oct 19, 2012 | 03:26 PM
Jet sitter's Avatar
Thanks for the info. You were absolutely correct. It was the wire. I changed them out for free, under warranty from Bosch. She's back to running like a raped ape, or maybe a slightly violated monkey.
96V6accord
Aug 25, 2007 11:42 PM
72mustang
Nov 25, 2006 01:35 AM
HondagalGA
Sep 3, 2006 11:34 AM
siggy
Jun 16, 2006 04:10 AM
richardn
May 2, 2006 10:44 PM
