Shifter lever button question
Old Apr 4, 2013 | 03:36 AM
revbjeff's Avatar
Default Shifter lever button question
Helping a friend with her 00 4 cylinder A/T Accord. She said she went to put the car into gear and the button on the shifter popped out. She then slid the **** off (I guess the screws were loose/missing). So I've ordered the replacement screws and spring for the button (she lost that too).
My question is how does the button stay inside the shift "****"? As of right now without the spring or anything the button just slides in and out. Does the spring kind of hold it on? Is there some kind of c-clip I'm missing?
I've scoured the internet but I've only managed to find info about 7th gen issues. This diagram (Honda Automotive Parts)doesn't show anything other parts so I'm kind of lost. She lives a little ways away so I'd like to have everything ready the next time we meetup.
Any help is greatly appreciated.
Thanks,
Brandon
Old Apr 4, 2013 | 12:12 PM
I recenlty had the button fail and glued it back together. The button has a slot which engages the flat rod extending from the shift lever. When you push the button, it forces the flat rod down the shifter to release the lock. The flat rod engages and retains the button.
The two screws should be tightened firmly, but don't strip!
panoman
Dec 7, 2012 06:45 PM
Chicken-Select
Sep 17, 2012 09:29 AM
MrGmo
Sep 28, 2007 01:40 AM
fendigyal
Oct 7, 2006 09:46 AM
DVan8504
Aug 30, 2005 12:40 PM
