Shifting to 3rd gear grinds
Old Sep 17, 2007 | 01:41 PM
jr_sanford
Default Shifting to 3rd gear grinds
I have a 1998 Honda Accord DX 2dr Hatchback that has 250,000 miles on it with a 5 speed manual transmission. When I shift from 2nd to 3rd I hear a grinding of gears.
I've adjusted my clutch so it disengages the clutch totally when the clutch pedal is depressed normally. Same issue. Then...
I replaced the (transmission) gear oil (it was low) with 85w-140 and it has reduced the grinding into 3rd gear somewhat. Also, if I let the engine RPM go down to below 2000 RPM and then shift up to 3rd gear I don't get any crunching/grinding sounds. All shifting into any other gear is just fine. Any suggestions?
email J.R. at jr_sanford@yahoo.com if you've got any solutions.
Thanks,
J.R.
Chehalis, WA
Old Sep 17, 2007 | 01:43 PM
sir_nasty's Avatar
Default RE: Shifting to 3rd gear grinds
What year, trim, motor etc are we talking about? We can assume that it's an accord but we need a little more information than that to answer this properly... And unless I am mistaken I don't recall any of the accords using gear oil in the transmission....
Put the car info in your signature and it will be there everytime you post
Old Sep 17, 2007 | 04:35 PM
Velocifero's Avatar
ORIGINAL: jr_sanford
I've replaced the gear oil with 85w-140 and it has reduced the grinding into 3rd gear somewhat. Also, if I let the engine RPM go down to below 2000 RPM and then shift up to 3rd gear I don't get any crunching/grinding sounds. All shifting into any other gear is just fine. Any suggestions?
Thanks,
J.R.
Chehalis, WA
uh, no. you look here if you want answers, not your email bullshi*. always use Honda manual transmission fluid. when i switched over, the grinding i had completely went away. problem solved.
Old Sep 18, 2007 | 11:31 AM
00AccordLX5spd's Avatar
Registered User
Easy there velocifero!
He's new to the forum....cut him a little slack
Old Sep 18, 2007 | 12:03 PM
korrupt1's Avatar
snychro sounds like its headed south...replace that and new fluid and should take care of the problem...my 91 is doing the same thing
Old Sep 18, 2007 | 06:12 PM
Velocifero's Avatar
ORIGINAL: 00AccordLX5spd
again, use Honda MTF, it's the best. better than synchromesh. slack?! man you know i dont like to sugarcoat things.
Old Sep 18, 2007 | 07:29 PM
Double clutching will allow you to avoid grinding until you fix the synchronizer. As you shift you pause in neutral, release the clutch, re-engage the clutch and shift up. Not exactly speed shifting, but easier on the nerves.
Old Sep 19, 2007 | 01:07 AM
deserthonda's Avatar
[quote]ORIGINAL: jr_sanford
Thanks,
J.R.
Chehalis, WA
[/quote
replace that 85w oil with honda fluid or at least 10w-30 oil,, otherwise it will burn up the 5th gear assembly 85w it too tick to lubricate 5th gear..
also,, you ask us to E-mail you ?? are you for real ?? like it was stated , you like answers , come back here
also,, it sounds like the syncro is worn ..
Old Sep 19, 2007 | 09:02 AM
Registered User
ORIGINAL: Velocifero
Man I know. I really just wanted to use that "whipped" smiley for the first time!
Fitnessinstbob
Aug 14, 2014 05:57 PM
leaded
Sep 7, 2008 09:05 PM
james_and7
Aug 28, 2008 11:29 AM
1993_accord
Sep 2, 2007 12:21 AM
Aug 11, 2007 06:28 PM
