Rough shifting in 3rd gear
Old Aug 14, 2014 | 11:44 AM
Fitnessinstbob's Avatar
Default Rough shifting in 3rd gear
I have a 1993 Accord 2.2 automatic.
I've been experiencing rough shifting in 3rd gear. It feels like a clunk. It happens when the car shifts into 3rd from accelerating and when the engine downshifts into 3rd gear.
I was reading on the forum about the TCU. Would a faulty TCU cause the rough shift?
I recently had all the engine and tranny mounts replaced, although they are aftermarket, not OEM.
I also had the tranny oil drained and replaced with a high detergent oil.
After driving a few hundred miles,
I replaced with Castrol Transmsax oil.
Any thoughts on what may be causing this?
Thanks!
Old Aug 14, 2014 | 04:07 PM
Is D4 or Sport Light flashing? If yes, extract the code and post for additional help. See DIY forum for guidance on extracting code.
I have heard that Castrol Transmax works well in Hondas, but most on this forum agree that Honda ATF works best for honda AT's. Suggest starting w/ 3 drain/refills w/ Honda ATF. This will eliminate most of Transmax.
Adjusting the throttle cable to AT (too tight) can change the shift quality. You should download a 90-93 Accord shop manual if you don't have one to guide this work. See DIY forum, Online Manuals post for a download.
Old Aug 14, 2014 | 05:57 PM
D4 and sport light are not flashing.
My transmission mechanic is the one that recommended Transmax.
That's what he put in after he drained the tranny detergent.
I will check the throttle cable and download the manual.
Thanks for the advice.
Rotten kid
Apr 21, 2012 08:43 PM
james_and7
Aug 28, 2008 11:29 AM
jr_sanford
Sep 19, 2007 09:02 AM
jayallen40
Apr 27, 2007 09:00 PM
play4801
Aug 27, 2006 01:31 PM
