Sponsored by:
Sponsored by:
Should CMC be changed when you replace CSC
Old 05-17-2014, 06:27 AM
Jet sitter's Avatar
Default Should CMC be changed when you replace CSC
I have a 2000 EX 5 speed. The Clutch Slave has a slow leak, I've been adding fluid about every 5 months. I've decided to replace it, but should I also replace the Clutch Master at the same time? I've ordered a Dorman CSC.
Old 05-17-2014, 09:26 AM
I think this is a personal decision to make.
Most shops insist on doing both at same time. Only time I ever had to replace a CSC, I had the CMC fail later. Not sure what that means, but that was my experience.
The CMC can be more difficult to access/replace than the slave.
Old 05-17-2014, 10:27 AM
Jet sitter's Avatar
Thanks for the feedback. I expect I'll be changing the CMC in the near future. I'll keep an eye on it, right now, it's as dry as a bone. Initially, the leak was sooo slow, that I had a difficult time to confirm where it was coming from. No doubt about it now, the boot is wet and you can see where the brake fluid has seeped outside onto the CSC.
Old 05-17-2014, 05:39 PM
holmesnmanny's Avatar
normally when you replace the master you replace the slave not really the other way around since the master is a little bit higher in labor time
just look at the master push rod ... if leaking replace it otherwise leave it
Old 05-18-2014, 11:45 AM
Jet sitter's Avatar
Manny, I ordered the CSC, it should be in on Thursday. I'll keep a close eye on the CMC.
Old 05-19-2014, 08:31 AM
Presumably the fluid is leaking out of the slave, and you've ruled out a leak in the line between master to slave? There's a rubber section in that line that might leak?
If you haven't found where the fluid is leaking out, you might want to look carefully around where the clutch-master pushrod comes through the firewall to the pedal. Fluid can soak into the padding underneath the carpet & you don't see it leaking.
Old 05-19-2014, 10:38 AM
Jet sitter's Avatar
Thanks Jim. I gave it another look to make certain it was dry around the CMC. It's fine. The leak has gotten much worse, I now can see fluid around the CSC, that's definately where it's leaking. I should receive the CSC today or the latest tomorrow. I may change out that rubber line while I'm at it.
Old 05-19-2014, 05:12 PM
just doublecheck the master pushrod as we said it will leak down it if its going bad
Old 05-19-2014, 05:22 PM
Internal leak (back into reservoir) is a bit different. In that case there's no loss of fluid inventory. No leakage OUT anywhere at all.
Internal leak symptom is that when you disengage the clutch (hold the pedal down) for a long time, it gradually engages and begins pushing the car to move.
Old 05-19-2014, 07:20 PM
Jet sitter's Avatar
The CSC is scheduled to arrive tomorrow, so I pulled the old one off tonight. Since the car is pushing 200K, I've decided to order the CMC and change it out also. I might as well bite the bullet and get the hydraulics sound. One less issue to have to worry about.
deserthonda
03-05-2020 11:11 PM
93Accord2.2
11-06-2013 11:53 PM
jrcastro
03-08-2008 10:33 PM
thunder_x
10-31-2007 07:34 AM
AndrewRWC
08-31-2006 10:11 PM
Quick Reply: Should CMC be changed when you replace CSC
