Should I use "Enzyme Treatment" for E10 gas?
Old Oct 16, 2010 | 11:14 AM
Jeff247's Avatar
Default Should I use "Enzyme Treatment" for E10 gas?
"The first problems encountered with transitioning to E-10 is the loosening of sludge from the fuel tanks. Ethanol is a very effective solvent and it will attack varnish, gum, and resins - the sludge that can build up in fuel tanks. Once cleaned off the fuel tank walls this build-up leads to poor performance and frequently clogged fuel filters and injectors. The enzymes in Star TronŽ will safely break down and disperse this sludge. After a filter change or two the fuel tanks will be clean and you can focus on the next, more serious, ethanol related issue."
I just heard about this stuff today. I am concerned about E10 negative effects on mileage and mechanics. Is it worth adding?
Here's one I saw. I'm sure there are many others:
mystarbrite dot com/startron//content/view/14/37/lang,en/
Old Oct 16, 2010 | 11:48 AM
I've never used the stuff, but I just changed your link so it's not active (per forum rules).
Old Oct 18, 2010 | 05:41 PM
Jeff247's Avatar
Default Honda says it's OK
I have a 2003 Accord and the manual allows up to 10%. Just keep hearing bad things plus less mileage. Everything around me is E10 now.
Old Oct 18, 2010 | 11:08 PM
Talking
|This sure is good ad copy you put in here...
ysbarney
Oct 1, 2012 06:04 PM
Reggi's-accord
Jun 6, 2012 07:17 PM
HondaAficionado
Nov 30, 2010 05:24 PM
sajithkaimal
Mar 5, 2010 11:38 AM
dksix
Jul 6, 2008 01:01 PM
