shut-off
1997 honda accord lx 2.2 automatic 4 cylinders
new gas filter
new egr
new fuel injector
new spark plugs
new timing belt
Engine crank right-up
idle normal..
problem is went press gas pedal ... engine shut-off
throttle adjustment look ok
Engine have all original part no modifications
new gas filter
new egr
new fuel injector
new spark plugs
new timing belt
idle normal..
A blocked catalytic converter could cause these symptoms. Try removing pre-cat O2 sensor or disconnecting exhaust pipe from manifold and see if symptoms are diminished or eliminated. If yes, new converter is fix.
Low fuel pressure might be a possibility, but it would need to be in a narrow range to allow starting but prevent acceleration.
Were you doing any work in the engine bay? Just wondering if maybe you plugged the MAP sensor wires/plug into the IAD plug and vice versa. Or maybe the G101 ground wire got loose.
tomd
Mar 9, 2013 06:35 PM
