Sideview Mirror Tightening
Old Jun 29, 2006 | 10:36 AM
wkugler
Default Sideview Mirror Tightening
I am having a problem that my driver's sideview mirror is loose where it folds in. The power function is working fine and a dealer told me it had to be comletely replaced but I have alot of doubts about this. It seems that you should just be able to tighten up the mechanism so it sits tighter. Any advice???
Old Jun 29, 2006 | 12:02 PM
deserthonda's Avatar
Default RE: Sideview Mirror Tightening
ORIGINAL: wkugler
Welcome to HAF.........sorry to inform you that in this occasion the dealer might be correct, you might have to replace the mirror assembly......
If you look up from the bottom of the mirror there are 2 holes, use a phillip screwdriver and see if the screws are loose,, if not , it is mirror time
Old Jun 29, 2006 | 12:27 PM
wkugler
Is there a safe way to pop off the 1"X3" access plate under the mirror assembly to get at the screws?
Alone
Sep 29, 2014 12:13 PM
Starps
Jan 18, 2012 03:02 PM
06ex24
Dec 14, 2009 09:16 AM
mxl360
Apr 30, 2008 07:52 AM
AKcord
Dec 22, 2006 12:25 AM
