Smoke and spark plug wires
Old Dec 15, 2011 | 11:08 PM
I think that it will be hard to see fluid movement.
When the car overheats, turn the heater on full blast. This will help cool down the engine to prevent damage.
When the engine is cold, turn on the a/c and check that both radiator fans are running.
Old Dec 16, 2011 | 09:24 PM
If the ac is not functioning, find "thermo a" on/near t-stat housing-follow the lower hose to where it connects to engine- there is a two wire green connector. Remove it, use a paperclip or wire and jump the two "wires" in the connector together (not in the switch-the wires ?? GRN and BLK ??), turn the car to "on" -doesn't have to be running, just the key to on - and see if BOTH fans on the rad come on.
Old Dec 17, 2011 | 11:46 AM
First90AccordMan's Avatar
Well the A/C is cold and does blow warm, but today I bought all new thermostat , gasket and temp coolant sensor, seems to be doing fine now. Thanks everybody for all the help.
sirtwist2
Sep 24, 2012 01:36 AM
wannakeepmy94Accord
Mar 14, 2012 08:06 PM
Savage
Oct 21, 2011 10:47 PM
deserthonda
May 29, 2006 03:28 PM
deserthonda
May 12, 2006 03:14 AM
