Smoking
Old May 10, 2014 | 08:41 PM
RobinsonRicer's Avatar
Heres a stretch- both the ac and coolant are mixing at the heater and theres an internal coolant leak at the same time.
I really have no idea, thats the only connection it would all have...maybe the two aren't related.
Old May 11, 2014 | 09:58 AM
TexomaAccord's Avatar
Anyone think maybe when I cleaned the egr passage that some gunk fell into the engine and that was burning it up causing it to smoke?
Old May 11, 2014 | 10:52 AM
Definitely plausible. Especially depending on what you used to clean the EGR. Seafoam by any chance?
When you recharged the AC it put a load on the engine which caused the stuff to burn up quicker. Drive the car around and see if it goes away.
Old May 11, 2014 | 11:41 AM
I cleaned the egr passage. It was completely clogged..
I used a brush, screw driver, piece of wire and some throttle body cleaner.
I did drive it around a bit afterwards, but never noticed it smoking..
It wasn't smoking at the first part of the a/c recharge, during the middle is when it started smoking... After driving a bit, the smoke went away, but I notice the smoke every once in awhile, but nothing as bad as the day it was sitting idle while putting ez chill in it.
I'm thinking (hoping) maybe one of these chunks of crud that was in the passage finally made its way down and started being burned off.
I haven't put any cleaner in the fuel system at all.
Old May 11, 2014 | 01:47 PM
I'm sure the AC and smoking are not related then. I'd be curious to see if they are though. Keep driving and see if you can repeat the event by other means.
Old May 23, 2014 | 04:50 PM
Ok, update.. Car doesn't smoke at idle, but does when accelerating from a stop.
PCV clogged maybe?
Old May 24, 2014 | 07:33 AM
  #17
Can't hurt to change the PCV - they are cheap and need to be replaced every now and then.
Old Dec 20, 2014 | 02:13 PM
  #18
Now its a blueish colored smoke lol --- silly car
Old Dec 20, 2014 | 03:22 PM
  #19
If no smoking at steady highway speed and begins to smoke w/ prolonged idle, and/or smokes heavily on acceleration after a prolonged idle, the valve stem seals are likely leaking.
6genex
Oct 30, 2007 01:46 AM
sUbLiMe96
Oct 5, 2007 01:15 PM
peaty
Jul 24, 2007 07:57 PM
nighthwkblkaccord07
Jul 13, 2007 12:16 PM
phylo
May 20, 2005 01:32 AM
