Smoking after Head Gasket Replacement
Old Jun 11, 2012 | 11:50 AM
Replace PCV and inspect/clean the PCV hose from valve cover to throttle body.
Note, was this engine smoking badly before the head gasket job?
Have you checked engine compressions? Excessive piston blowby can also load up the crankcase pressure and push oil into air intake.
Smoke in video is oil smoke. Steam is much whiter.
Old Jun 11, 2012 | 12:36 PM
GoneHonda's Avatar
It smoked but not even close to this bad..
Old Jun 11, 2012 | 06:54 PM
GoneHonda's Avatar
Cleaned PCV valve with some carb cleaner, also cleaned and checked crank case hose as well( not sure what else to call it) it doesn't smoke hardly at all, until i give it some gas, it them smokes as long as the throttle is open.. and seemingly ceases after it is closed or at idle.
Old Jun 11, 2012 | 07:29 PM
Roader's Avatar
Does the smoke smell like burning oil or antifreeze?
Old Jun 11, 2012 | 07:52 PM
GoneHonda's Avatar
Smells like Oil and the video Texas verified was OIL smoke..
Old Jun 11, 2012 | 09:49 PM
I would drive for a while and see if things improve. Maybe lot's of oil from PCV in intake to be burnt. Otherwise your symptoms indicate oil bypassing one or more oil control rings on pistons.
Lukes95coupe
Jul 14, 2011 08:11 PM
nighthwkblkaccord07
Jul 13, 2007 12:16 PM
thunder_x
Jul 9, 2007 11:57 AM
dodins
Mar 18, 2007 08:10 PM
phylo
May 20, 2005 01:32 AM
