somethings in my oil
Old Jan 25, 2006 | 07:05 AM
jchicks
Default somethings in my oil
I recently picked up an 86 accord lx. I knew it had some problems, but it was only 70 bucks. When i drained the oil, i drained out nearly 10 quarts. I dont think it was all oil though. What could be getting in my oil.
Old Jan 25, 2006 | 11:05 AM
deserthonda's Avatar
Default RE: somethings in my oil
Wow 10 qts sounds way too much,,,, if someone did not overfill it with oil ,, it could be coolant,,,could also be gasoline if carb is flooding over,, but 10 qts ???
Old Jan 25, 2006 | 12:11 PM
RTexasF's Avatar
Super Member
I agree. It's got to be coolant judging by the quantity. Warped head, cracked block, blown head gasket.........?
Old Jan 25, 2006 | 09:12 PM
lightshow's Avatar
now you gotta look into the oil and see what else is in there, because oil and just about anything else, doesnt mix very well, so if you see green liquid separating from the oil, you know that it is coolant, which it most likely is, and the problem with the highest probability would be the head gasket, which is very easy to replace. what model is your accord, is it an lx-i?
lightshow
Old Jan 27, 2006 | 06:52 AM
EMEX's Avatar
do you have blue smoke coming out of your tailpipe? if you do then it's fuel. in that case you need to take apart the block and replace the piston rings. this is also known as a blowby.
Old Jan 27, 2006 | 10:49 PM
deckerhonda's Avatar
i believe you meant to say it is oil that burns blue.
Old Jan 28, 2006 | 12:42 AM
lightshow's Avatar
yea def...blue = oil
badfish
Feb 4, 2015 11:49 AM
MiyashiMeism
Sep 5, 2010 02:12 PM
jasonan
Aug 28, 2009 11:26 PM
thunder_x
Oct 22, 2006 09:56 AM
nygamble
Jun 11, 2006 07:13 PM
