Spark Plug Stuck
Old May 27, 2006 | 08:24 PM
Rizzie
Default Spark Plug Stuck
Whats good peoples, I got a 94 accord ex and in the 3rd chamber the damn spark plug is stuck. i twisted it as hard as i could without snapping it but if i go any harder on it its gonna snap. is there some other way to ease it up or somethin?? thanks
Old May 28, 2006 | 12:58 AM
deserthonda's Avatar
Default RE: Spark Plug Stuck
ORIGINAL: Rizzie
DO NOT and i repeat DO NOT force the plug out,,, whomever installed it problaby cross theraded it..........
here is what you do,, spray some wd-40 in the hole, let it soak for a bit,, get a plug socket and a 3/8 small breaker bar, you need to go back and forth little by little ,, you have to be patient , cause if you brake the plug , you might have to remove the head to fix it.. Anyho, after going both way , go about 1/4 turn out ,, so little by little it will come out,,
I am sure the threads in the head ars gone, so you need to retap the plug hole ..after you retap it there is going to be some metal filings , you cannot get a magnet cause it is aluminum so get a small round object, put grease at the end of it and go in the plug hole to pick up as much metal filing as possible, Now if the threads are totally gone , installing a heli coil might be needed to make sure you can reinstall the plug in there properly
If you do not have a clue of what i am talking about it is best to take it to a shop ..
sirtwist2
Sep 24, 2012 01:36 AM
SeanAccord
May 18, 2010 08:24 PM
offroadTRD
Jul 3, 2009 06:38 AM
jon02accord
Mar 26, 2008 10:54 AM
Accord_Ras
Dec 10, 2007 10:21 AM
