Specific electrical issue RE: Small light fuse.
Old May 22, 2013 | 07:42 PM
blue94ex's Avatar
Default Specific electrical issue RE: Small light fuse.
I woke up this morning and went out to my car to find that the left turn signal was on, and not blinking. I turned the car on, and tried to mess with the fuses so see if I could get it off.
Unfortunately, it turns out there was a 30A fuse in my 15A small light fuse slot. The small lights circuit is the problem, but I totally need it to drive becuase without it I have no break lights.
As of now, I move the small light fuse to a spare slot when I park, and put it back before I drive. I took out the turn signal lights top front left and back left but didn't bother removing the front bottom left.
I have to hand signal when turning left, as my right turn signal functions normally.
Hazard lights turn on but do not blink.
If anybody knows where I can start looking to solve the issue of where the short is I would be greatly appreciative.
Old May 22, 2013 | 08:13 PM
blue94ex's Avatar
I have found the location of the electrical issue on a wiring diagram, I just don't know how to access this wire yet. I am going to investigate, but I doubt I will get very far without some very specific advice.
Old May 23, 2013 | 12:08 AM
One the font bumper, or right under it, there is a ground bolt with a bunch of black wires feeding into it. There is one on the passenger and driver's side of the bumper. I would unbolt them, clean the bolt and bracket with some sand paper or a wire brush and reattach.
Let us know what you find after cleaning these grounds.
Old May 23, 2013 | 07:00 PM
blue94ex's Avatar
I was wrong when I said I have no brake lights with teh small light fuse taken out... the small light fuse takes out my running lights, dash gauge lights, and the clock dimmer (when I turn on the headlights).
Figured out by removing the small light fuse, my turn signals work just fine, but I have no running lights, so I can't drive at night. Or I can put the small light fuse in the drive at night, but I will have to hand signal my left turns and take it out when I park.
Talked to an expert friend who thinks it is probably the turn signal switch. I think that's entirely possible.
Old May 23, 2013 | 08:05 PM
You can do tests on the headlight switch to verify by using a volt meter.
Old May 23, 2013 | 08:11 PM
blue94ex's Avatar
I don't have a volt meter, but I could get one... I am planning to just buy a new switch on amazon before I crack open the column so I can swap it out if its the problem or just return it if it's just a wire somewhere... I looked around for the grounds you talked about but I couldn't get underneath today because it was raining and I was at work.
would love a picture of the ground bolt?
My accord is a 1994 EX manual
Old May 25, 2013 | 08:59 AM
See this post, go to post #6. Some pictures of the ground (g201 and g301) that PA is talking about.
https://www.hondaaccordforum.com/for...se-help-34362/
simplyjessi
Mar 18, 2015 02:15 PM
Uberpippi
Feb 1, 2013 10:09 PM
moddisonj
Dec 18, 2012 10:56 AM
dalejamin
Jul 27, 2011 07:41 PM
calenatar
Feb 12, 2007 10:18 PM
