speed senor
Old Jul 25, 2013 | 09:22 AM
5star's Avatar
Default speed senor
I have a 97 Honda accord DX auto Non vetc.when I was rebuilding the engine the speed sensor wires came out of the 3 pin connector and I have no idea which order the go back I . I have tryed the internet and the manual so dose anyone know or have a pic of it. Thanks guys.
Old Jul 25, 2013 | 09:32 AM
Dr. Drivability's Avatar
here ya go:
Old Jul 25, 2013 | 10:23 AM
Yep. ^
It is also shown in the service manual under Electrical, Gauges, Speedometer/Troubleshooting
Old Jul 25, 2013 | 04:37 PM
5star's Avatar
Thanks guys
Old Jul 25, 2013 | 09:35 PM
5star's Avatar
I put the wires back in the connector and drove it still it don't work and I get a code of P0501. Vehicle speed sensor A range/performance how would I trouble shoot that and what dose that mean. I replaced the VSS and i test the black wire and the orange wire and it has around 5 volts. The yellow wire and black wire have around 12 volts. When i block one wheel and turn the other the volts don't pulse on the orange wire. I ran a new wire from the dashboard to the vss to replace the orange wire. I switched out gauges on the dashboard and the same thing. Any ideas whats next. I don't know if its related but when driving the car sometimes revs high like its don't know when to shift. I don't know if its because the speed is not being displayed. also the drive shaft in side the vss doesn't spin when i turn the wheel how would i fix this. I think it may be the root of the problem.
Old Jul 27, 2013 | 06:34 AM
Recheck the "pin" between the vss and the trans.
Was this happening before the engine swap?
Old Jul 27, 2013 | 09:30 PM
5star's Avatar
it was the pins it finally back together and works thanks guys.
Old Jul 28, 2013 | 01:01 AM
Way to go 5star..now don't forget to come back in and keep up with the fixins of these fine cars..Good work Mods..
understand1
Nov 10, 2012 11:06 AM
irhunter
Mar 23, 2011 04:49 PM
SirJohnIII
Nov 18, 2010 03:21 PM
Spadinator
Oct 23, 2010 12:50 PM
Flotown4
Sep 4, 2009 02:57 PM
