Speedo stopped working, got this code
Old May 17, 2012 | 04:35 PM
  #21
crispin's Avatar
I PM'd someone who knows more about that then I do.
Hopefully he will answer shortly.
Old May 17, 2012 | 05:41 PM
  #22
Old May 17, 2012 | 05:50 PM
  #23
crispin's Avatar
Thank you redbull
Old May 18, 2012 | 10:34 AM
  #24
Tyler Joyce's Avatar
Thanks guys. You are awesome.
Old May 18, 2012 | 10:43 AM
  #25
crispin's Avatar
let us know if and which reset procedure worked for you.
Old May 18, 2012 | 10:49 AM
  #26
The above processes labeled SRS worked perfectly without hassle. Simple instructions and really easy to do for future refrence
Old May 18, 2012 | 11:44 AM
  #27
crispin's Avatar
cool
I am going to paste the info here in case that link goes bad one day
1. turn ignition switch off, remove service connector cover (yellow plug cover pictured above.)
2. connect (jump) the MES (Memory Erase Signal) connector (this is 2 pin connector wrapped on yellow plugged in the front of the underdash fuse box)
3. turn ignition switch on
4. SRS light will come on for 6 secs then go out, remove the jumper within 4 secs after the light goes out.
5. the SRS light will come on again, reconnect the jumper within 4 secs after the light has come on.
6. the SRS light will go off, remove the jumper with in 4 secs after the light has gone off.
7. the SRS light will blink 2 times indicating the memory is reset.
8. Turn the ignition switch to off and wait for 10 seconds.
civilfox
Oct 15, 2023 01:49 PM
chill1022
Jul 19, 2006 11:14 AM
jrschmank
Jun 4, 2006 07:13 PM
jayallen40
Dec 4, 2005 10:46 PM
88COMMUTER
May 26, 2005 10:03 PM
