Speedo works intermitten
Old Nov 15, 2006 | 03:42 PM
RICHARD's Avatar
Default Speedo works intermitten
Hello fellow Honda owners, I am back with another Honda issue. My 1990 Accords speedo works when it wants to. One minute I am drivin, works fine, then it drops to zero. Most of the time, the S light will start flashing shortly after. Any ideas? Thanks
Old Nov 15, 2006 | 03:49 PM
YeuEmMaiMai's Avatar
Default RE: Speedo works intermitten
Vehicle Speed Sensor is the first thing I would check since your speedo quits and your S light begins to blink
Old Nov 15, 2006 | 09:02 PM
deserthonda's Avatar
ORIGINAL: YeuEmMaiMai
Old Nov 20, 2006 | 03:47 PM
RICHARD's Avatar
Problem is the speed sensor, howerver I don't have $140.00 bucks to replace it so I will just live with it for a while. Or at least until it quits all together. Thanks for your help.
Old Nov 20, 2006 | 04:35 PM
you can remove disassemble clean and regrease with high temp diaelectric grease and reassemble. should fix your problem
Old Nov 20, 2006 | 10:58 PM
RICHARD's Avatar
Ok, thanks.I will give that a try this weekend.
naveen_jaina
Jan 10, 2014 07:10 PM
Junkers101
Feb 19, 2011 12:24 PM
wingman2300
Aug 16, 2010 03:39 AM
9JordonAccord9
Sep 28, 2005 01:27 PM
98blkaccordex
Aug 31, 2005 01:53 AM
