Speedometer not working
Old Mar 10, 2009 | 04:03 PM
hffej54
Default Speedometer not working
I have a 92 Accord LX with an automatic transmission and the speedometer has stopped working. The cruise control still works. Occasionally it comes back to life, but for the most part it does not work. The odometer also does not work but will start to work when the speedo starts working. I am guessing that since the cruise still works that the speed snesor is not the problem? If it is the speedometer can it be fixed?
Thanks, Jeff
Old Mar 10, 2009 | 04:23 PM
There are places that fix speedometers, but you can also get one from a junkyard.
First, check for loose connections at the back of the cluster.
Old Mar 11, 2009 | 11:49 PM
honda86's Avatar
my speedometer stops working but when it does it cause other things to go wrong like the check engine light will come on and the car will act sluggish and starts to lose power WHY ? (baffled)
Old Mar 12, 2009 | 03:37 AM
Honda86, you should put your year/model in your signature so we know what kind of car you have.
You likely have a different problem. When the check engine light comes on, the engine computer has detected a problem and stores a code. You likely have a bad vehicle speed sensor (VSS) or the wiring, but you should diagnose first.
If your car is an 86 from your username, then you can short a service connector under the glove box with a piece of wire or a thin paperclip. You can also download an 86 shop manual from the Online Manuals thread in the DIY section. It will have detailed information on how to troubleshoot the problem.
Old Mar 14, 2009 | 04:39 PM
honda86's Avatar
Default Help
okay updated my signature now im so confused on whats really going on im chasing to many leads about this problem the speedometer isnt working and when it stops working my car looses power but when i let it go it aometimes it will get the power back but then it starts to smoke like crazy but that might be something else so if anyone has anything that might help me plz do im so frustrated thanks alot
Old Mar 14, 2009 | 06:16 PM
Honda86, your check engine light came on, so you should find out what code was stored in the engine computer.
The tegger.com referenced in the sticky threads has the procedure to get you CEL.
See: http://www.tegger.com/hondafaq/faq_ii.html#retrieve
Click on "This PDF Document". The procedure for the 90 accord is on page 15. The diagrams referenced in the procedure are on page 18.
All you have to do is pull back the pass. carpet and count the flashes by the ECU when the key is turned on. Post the code(s) on here.
Old Mar 14, 2009 | 06:36 PM
Cool Seems to be two post going here guys:
Make sure when you new guys post that you start up your own thread and not run over someone elses post next time...
Thanks Guys
forestcd6
Jan 10, 2018 12:42 PM
1joker069
Feb 12, 2009 03:16 PM
accordEX99
Nov 3, 2008 02:22 AM
sebastian
Jan 9, 2008 12:10 AM
cclc31
Oct 25, 2005 09:27 PM
