Speedometer problem
Hi,
I've got a 1998 Accord, and the speedometer doesn't work. The speed sensor has been replaced, and the mechanic said he tried a couple, thinking the first was bad. But, still no speedometer. The mechanic now thinks it's the connector that plugs into the speed sensor.
I took out the sensor yesterday, and then cleaned off the contacts on the connector. I also lubricated the contacts with a little dielectric grease. Still, no speedometer.
The Check Engine Light remains on. The code is PO500, which is the Vehicle Speed Sensor Circuit malfunction.
To complicate matters, the car is a manual transmission, and the connector to the speed sensor is unavailable unless you want to buy the whole wiring harness for about $450. Maybe a junk yard would have one, but there were only about 10% of Accords with a manual, and the automatics apparently have a different connector (can anyone verify?).
So, if anyone has any relevant info, please share it with me.
Thanks
Randy
1998 Honda Accord, 2.3 4-cyl., manual trans.
Thanks
Randy
It would be best to test the VSS wiring on your car. Refer to a service manual for the detailed steps.
Only the manual transmission uses the traditional VSS for the speedometer. On the automatics, the speedometer circuit gets the pulses from the PCM; which it reads from the output shaft speed sensor (aka countershaft speed sensor).
Turn the key to the II position and unplug the VSS. The blk/yel wire should have 12V to ground. The blu/wht wire should have 5V to ground. I use a valve cover bolt or the negative battery terminal as my ground. The black wire should have continuity (zero resistance) to ground.
I pulled off the connector. The wires have the correct voltage, but when I insert the probe into the connector the black/yellow doesn't have anything. So, the connector is bad. I need to find one, or try to repair mine.
If anyone knows where to find this connector please let me know.
Thanks again,
Randy
Thanks again,
Randy
I measured the 12V on the blk/yel wire itself. It actually pulled out of the plastic connector...probably by someone who pulled on the wires instead of the connector when they changed the sensor. I am pretty sure that's the problem; the conductor in the connector is separated. I tried to repair it without success.
However, I do think I have found a new replacement. It's made by Dorman, part
645-916. It looks the same in this photo:
Dorman Products - 645-916
If it doesn't work I will likely go to the Pick a Part and try to find one on a junked car.
Randy
Randy
james.walters
Mar 13, 2007 04:43 PM
