Speedometer working intermitatley
Old Oct 31, 2011 | 09:50 AM
m6 c5's Avatar
Default Speedometer working intermitatley
Sometimes the speedo works and most of the time it doest. Im thinking it is a grounding issue but I dont have any idea as to where to start looking.
I downloaded the electrical diagrams from the diy section but they arent labeled so I dont know which to click on...
Any help is appreciated.
Forgot to add, it is a 97 accord, not sure of the specific model as it is my girlfriends but it does not have vtec and its an auto.
Old Oct 31, 2011 | 10:34 AM
Is the check engine light on? If yes, you can retrieve the trouble code, which may point to the vehicle speed sensor (VSS).
However, if no check engine light, it may be the speedometer circuit board. You can use another one from another Accord and replace it. See this thread:
http://honda-tech.com/showthread.php?t=2460328
Copy and paste without quotation marks (" ") to view.
I've been studying the circuit board for a while now and I think the problem may be due to a faulty component, the ceramic resonator. If you are willing to spend a few bucks to test with the bad circuit board, see this other thread. No guarantees on whether this is the faulty component though.
"http://honda-tech.com/showthread.php?t=2992609"
Old Oct 31, 2011 | 10:46 AM
Lightbulb
That was a good link for that problem..Your on the ball Redbull-1
Old Nov 1, 2011 | 01:36 PM
m6 c5's Avatar
Speedo Works randomly - Honda-Tech
Well there is no check engine light and she can set the cruise when the speedo is not working so Im pretty sure its not the vss. So it looks like Ill be making a trip to the junk yard for a new circuit board as there doesnt appear to be a definite fix for it besides replacement. I guess I need to look at one that would have relatively low miles on it as hers has close to 200k on it and I assume its less likely to have a problem the fewer miles the car has on it.
BSims66173
Nov 9, 2012 11:52 AM
sebastian
Jan 9, 2008 12:10 AM
96accord
Nov 21, 2006 03:05 PM
chill1022
Jul 19, 2006 11:14 AM
cclc31
Oct 25, 2005 09:27 PM
