squeaking noise help!!
So new person to this forum. I have a 1994 Honda accord ex 2.2L vtec. It just broke 313,000 miles and the suspension is finally going out. My passenger side squeaked first. Apparently I didnt get to it on time and my ball joint and cv axle broke. I fixed that. Now the driver side squeaks. Btw I believe that the ball joint is the cause. So all in all I just replaced on both front sides, the lower ball joints, cv axles, upper joints and arms, struts, outer tie rod ends, and sway bar links. I was going to do the inner tie rod ends this weekend with an alignment, but after I changed everything the squeaking came back after a day. I took the joints off and greased them. Put them back on and still squeaking only from driver side. So now I'm clueless on what it could be. Any help??
Anti-sway bar bushings (horizontal bar bushings) can squeak when dry. Remove bushing guide, lube, and reinstall.
A worn upper ball jt, lower arm bushing, or radius rod bushing could also produce a squeaking sound. Bushings should be very tight. Cracks in surface are not necessarily a problem.
Rupert305
Apr 4, 2010 04:40 PM
